the li-ion battery started pulsing so put it on charge
10 mins later noticed the red light ouch 3 attempts at resetting no go
then i thought take the spare charger indoors plugged it in the same
back out the worksop to finish assembly off dresser top
then it dawned on me i had been working quite hard and hadnt noticed the temperature had dropped to below 9 degrees
ryobi batteries and chargers along with other manufacturers will not charge hot batteries until they cool or wont charge if the temperature is too cold or too hot
so remember leave your battery and charger at room temperature for 30 mins iff it wont charge to warm up/cool down before deciding its failed
