Shuttering for concrete base - what to do next?
valve90210
Been thanked: 2 times
Post by valve90210 »
Hi all
Yesterday I put together some shuttering for a concrete base I want to make for a bbq etc. Now, because my lawn is so all over the place, to get it level with an existng concrete base, by the time I'd taken the turf off to go else where, some of the ground is lower than the level of the shuttering. what is the best course of action? Should fill the bottom and under the shuttering up with soil before I put down the hardcore and the base?
A couple of pics which illustrate the gaps...
Any thoughts would be much welcomed, I'm sure it's simple but I can't get my very tired brain round it today.
Has thanked: 47 times
Been thanked: 2554 times
Re: Shuttering for concrete base - what to do next?
I would have though the soil will wash / move away. I would put down more hardcore, then compress it. Others may have differing ideas
Job and Knock
Old School Chippie
Has thanked: 742 times
Been thanked: 1573 times
Post by Job and Knock »
You certainly need to ensure that there are no gaps beneath the shutterings, othgerwise it will all flow out
valve90210
someone-else wrote:I would have though the soil will wash / move away. I would put down more hardcore, then compress it. Others may have differing ideas
Yeah, could be right re the soil
Job and Knock wrote:You certainly need to ensure that there are no gaps beneath the shutterings, othgerwise it will all flow out
That's what I figured.
What if I was to fill in the shuttered area with soil and compact it down as best I can so the bottom is level with the shuttering, would that work?
Timllfixit
Has thanked: 146 times
Been thanked: 209 times
Post by Timllfixit »
A few bags of gravel should fill those gaps, and the edge of the grass will stop it moving outwards.
pfb5
Has thanked: 67 times
Been thanked: 106 times
Post by pfb5 »
You can shove anything (rigid) you like down there - bits of hardboard - just enough to prevent the concrete flowing out, while it sets. Or cardboard, backed up with soil on the grass side, the cardboard will deteriorate over time.
Excess concrete is cheap. If it's deeper on the lawn side, you're not going to see it.
valve90210
Cheers guys, that gives me something to go on, I think I have a bit of a plan now, I have some hardboard knocking about somewhere.
Return to “General DIY forum”
