I once watched a video on YouTube called “the maximum torque challenge”, which was allegedly uploaded by Everbuild. In this video a bloke was sticking block pavers to a vertical surface using grab adhesives and surprisingly only the maximum torque actually worked and all the others failed this test. So I decided to repeat the test and got far different results using the exact same brand of grab adhesives that Everbuild used in their test-
Then I thought I would go a little further and then rigged up a hydraulic test to see which grab adhesive would endure the most force before de-bonding. This test was interesting as some of the grab adhesives that I expected to be good were not at all good.
I did get quite a lot of comments on YouTube and several people suggested other brands of grab adhesive, so I then completed another set of tests using some other brands of grab adhesive-
Out of all the adhesives tested my favourite is the Nemesis brand sold by Screwfix, not only did this pass the vertical grab test but it also stuck so well that the block of timber used on the test rig actually split in two before the adhesive de-laminated. The Sticks like sh*t and also C-T-1 also broke either the block of wood or delaminated the plywood as well!
In total 12 different brands of grab adhesive were tested and the required pressure to break the bond is listed below as well as the price-
- Maximum Torque – 425 PSI. Cost £9.35
- Soudal Fix All – 540 PSI. Cost £5.99
- Evo stick. Sticks like sh*t – 608 PSI. Cost £5.99
- Unibond mega grip- 297 PSI. Cost £4.99
- Nemesis- 594 PSI. Cost £5.99
- GRIPFILL - 202 PSI. Cost £2.49
- PINKGRIP- 228 PSI. Cost £2.45
- No more nails - 265 PSI. Cost £4.99
- ADISEAL- 362 PSI. Cost £9.00
- Serious STUFF - 397 PSI. Cost £11.99
- Geocel The Works- 528 PSI. Cost £7.99
- C-T-1 - 642 PSI. Cost £10.20
