Cooker hood installation
Grillz
Has thanked: 3 times
Been thanked: 2 times
Post by Grillz »
Hi all, hope you're well on this chilly morning?
I want to install a hood over my cooker and have it vent outside. I plan to use 100mm rectangle ducting along the top of the cabinets and then out through the wall. My concern is that on the exterior, about the place where the vent will be is an air brick.
What are my options and considerations here?
You may also notice a previous vent which is now covered by a unit. Not sure what the story was with that.
Cheers pro's!
aeromech3
Has thanked: 177 times
Been thanked: 665 times
Re: Cooker hood installation
Post by aeromech3 »
I have a similar position "air brick" in my house 1989 build; it was the old outlet for an extractor x'pelair type fan which was made redundant with the newer kitchen fit; what does your neighbour have inside, as it looks more inline with the top of the window and cabinet than blocked by the cabinet, perhaps your duct has been plastered over.
Grillz
Post by Grillz »
The question I'm asking is more about how to vent out if the hole I core is on the other side of the air brick. Is that ok to do and do I need to do anything special?
aeromech3
Post by aeromech3 »
Understood but perhaps a builder can confirm but I don't know why you would have an "air brick" at this height so I questioned, perhaps wrongly, if it was a previous vent!
Grillz
Post by Grillz »
I think it is there to vent as there is an inside vent, now covered by a kitchen units. Weird though, as they seem to be at different heights.
aeromech3
Post by aeromech3 »
The stagger on the original vent might be to do with the window lintel but again need a builder to answer!
Grillz
Post by Grillz »
And I get what you were trying to say before now mate, sorry if I came off like a blunt tool!
OchAye
Has thanked: 855 times
Been thanked: 994 times
Post by OchAye »
Do other houses (next to you) have a vent up there? It might help a bit.
Return to “General DIY forum”
