emulsion peeling off paintable wallpaper
- Has thanked: 76 times
Hi everyone. Never seen this happen before but I hung some BQ vinyl paintable wallpaper and covered with BQ kitchen and bathroom emulsion only to find after six months the surface is sticky and paint is peeling off.Has anyone got any suggestions? It looks to me as though the paint itself is not compatible but I cannot think why.I have used the same wallpaper elsewhere and covered with Dulux soft sheen with no problems at all/Thanks
- dynamod
- Elephant Man
- Has thanked: 592 times
- Been thanked: 1444 times
Re: emulsion peeling off paintable wallpaper
Sounds like a problem with the emulsion. Insufficient binder in the mix perhaps?
I'd steer clear of anything with B&Q branding if I were you, and stick to the recognised trade brands.
Nihil expectore in omnibus
dynamod wrote:Sounds like a problem with the emulsion. Insufficient binder in the mix perhaps?
someone suggested to me to paint an undercoat over it and then a more reliable emulsion, rather than starting all over again
it appears that vinyl emulsion doesn't react at well with vinyl wallpaper, regardless of what make one uses.Kind of begs the question- why is this not mentioned on the containers?
- dynamod
- Elephant Man
Depends on the sheen of the vinyl paper to a large extent, as a lot of textured blown vinyls will take emulsion without any problems.
If there is a particularly shiny finish and a low texture, you may run into problems. I'd use an acrylic primer as a base coat in these situations.
