skirting board along bath edge
- Has thanked: 2 times
- Been thanked: 5 times
im after some help/ideas on the best way to fix the skirting board along the bath panel, id really like to fix it without the fixings being seen but of course it may need to come off at a later date so i cant really use brad nails. i had also thought of using magnets but there is no where to counter sink them in to due to the bath panel only being 1mm thick ish.
just looking for ideas how others have got round it or have you just use screws?
- Cantseeitfrommyhouse
- Has thanked: 36 times
- Been thanked: 108 times
- wine~o
- Has thanked: 1414 times
- Been thanked: 3998 times
Re: skirting board along bath edge
Bath panels don't normally have skirting boards on. maybe a little bead of silicon or summat ??
- Has thanked: 61 times
- Been thanked: 319 times
what about
Screw caps,
Mirror screws wont look too bad but stand out
Countersink hole in skirting board and fill over screw hole then paint find with magnet if you need to unscrew
Screw caps,
- Timllfixit
- Has thanked: 146 times
- Been thanked: 209 times
Cut it at both ends and secure to bath panel as above? Then when you remove the panel the section of skirting will come off with it.
- These users thanked the author Timllfixit for the post:
- Rossl1985
ahh now thats a good idea (why did i not think of that oneTimllfixit wrote:Cut it at both ends and secure to bath panel as above? Then when you remove the panel the section of skirting will come off with it.
![scratch :scratch:](./images/smilies/icon_scratch.gif)
this is the reason i needed to use skirting board along this edge of the bath, the bath has been raised up for some reason and i never thought about removing it when i had the bathroom pulled apart
![Image](https://i.imgur.com/PKIZ3NV.jpg)
![Image](https://i.imgur.com/bBoU7dg.jpg)
![Image](https://i.imgur.com/lNt4deV.jpg)
although i do think the skirting board works well and if its screwed to the bath panel from behind it should help to keep the fibreglass panel straight
![Image](https://i.imgur.com/mrO7wde.jpg)
sorry about the dust in the room its hard to keep things clean with trying to get the other rooms in the house done
