My kitchen tap comes with copper tubing connected directly to the old tap, but my new tap comes with 2 connector tubes with some adatpors, not sure any advise or any thing else i need to get to replace it please?
Change kitchen tap
- Has thanked: 108 times
- Been thanked: 1038 times
Re: Change kitchen tap
Pop out the copper tube, cut it off, fit an isolator valve and then screw the new fittings on to the valve. That's what I do anyway.
- Has thanked: 250 times
- Been thanked: 212 times
Same here, quick easy jobRorschach wrote:Pop out the copper tube, cut it off, fit an isolator valve and then screw the new fittings on to the valve. That's what I do anyway.
- Has thanked: 810 times
- Been thanked: 3502 times
Sometimes it is worth the hassle of unclipping the sink top to lift it and giving yourself a bit of room to work. The only issue then is if you mess the gasket up for the sink to worktop. You can get a new seal strip off Amazon for a fiver.
