A quick tip when opening a stopcock is to never open it fully as you run the risk of it seizing in the fully open position.
- Plumbing Videos
- stop tap opening, stopcock opening, stopcock closing
How to use PTFE tape
by admin 3,757 Views -
How to replace a stop tap washer
by admin 4,310 Views -
Cutting plastic pushfit pipe | John guest pipe
by admin 4,783 Views -
by admin 7,368 Views -
How to connect flexi tails
by admin 4,574 Views -
by admin 5,602 Views -
Cutting copper pipe using a pipe slice
by admin 3,339 Views -
Stop spiders on security cameras | stop spiders on CCTV
by admin 1,184 Views -
copper pushfit fittings | cuprofit
by admin 21.3k Views -
How to make a stopcock key | Make stop tap key
by admin 1,104 Views -
by admin 32.8k Views -
by admin 26.1k Views -
by admin 18.6k Views -
by admin 10.1k Views -
by admin 5,657 Views -
by admin 8,144 Views -
by admin 8,831 Views -
by admin 7,553 Views -
by admin 4,406 Views
