Hi
i want to add a new light in my loft i have located a 1.5 mm wire that lead to a ceiling rose my question is can i cut in to this wire(with the power switch off )add a junction box and come out with 1.0 mm or do i have to use 1.5 as is already used in the circuit any advice appreciated.
loft light
- sparkydude
- Has thanked: 2 times
- Been thanked: 149 times
It depends on the rating of the lighting circuit fuse, if it is a 10A fuse or breaker then use 1.5, or if its a 6A then 1.0mm is fine. Just make sure the cable you are proposing to tap into is a permanent feed and not a switched feed from another junction box.
Nick
Nick
- Electrician
- Contact:
