The Right stuff vs Weetabix
- Has thanked: 7 times
- Been thanked: 3 times
A Hornet in my Bonnet.
Why the norm of using chip board, MDF and other manufactured boards so readily in furniture making when solid timber will provide so much more - at not always so many pence more?
It IS rubbish and for a small amount more you could have had ...
Yes, they are in big sheets, but should that be the defining moment in furniture making?
BUT do some milk the cow when using solid softwood instead.
Time for those who care about quality (producer and customer) to challenge the market and demand what should be the norm at affordable prices.
Rip off Britain needs the Grim Reaper!!
Your thoughts?
Your thoughts?
- Has thanked: 736 times
- Been thanked: 2341 times
different markets realy
people want cheap and cheerfull
and some want traditional quality
some expect quality at cheap and cheerfull prices
some people expect hand built individual furniture to be cheaper than argos
as in can you make this display unit any cheaper than the £169.99 in the catalouge
- Pro Cabinetmaker
Flat pack is produced on CNC machines which require uniform sheets of consistent material in uniform thicknesses. The cost of MFC is well below that of even the cheapest, nastiest pine board. It is also much more consistent, so from the point of manufacturing making stuff out of MFC is a lot cheaper. However, what those robbing barstewards called retailers do to the prices needs to be seen to be believed......kabous wrote:Why the norm of using chip board, MDF and other manufactured boards so readily in furniture making when solid timber will provide so much more - at not always so many pence more?
My probl;em is how do I persuade someone with IKEA pockets to buy Heald's quality - at somewhere in between prices. Flatpack hasn't ruined the trade - good old British stinginess and penny-pinching has
Scrit
Measure twice, cut once - except fingers!
- dirtydeeds
- Craftsman Carpenter
scrit is perfectly correct, its MFC and computer contolled manufacturing are perfect partners
MFC is delivered in perfect sheet sizes of perfect thickness. Computer controlled saws, CNC and Drilling machines do the rest.
You only need a couple of skilled CAD operators and an army of unskilled labourers to pack and label them. The size of the army depends ONLY on the speed the machines output
- Gas/Heating Expert
- Been thanked: 9 times
- plumbing and property
It probably is for a CNC machineScrit wrote:Perfect sheet sizes? Since when is a 2.6metre x 2.0metre sheet at 95kg a perfect size?dirtydeeds wrote:MFC is delivered in perfect sheet sizes of perfect thickness
Scrit
Treat everyone like they are a rich distant relative, in whose will you'd like to be remembered.
