Purchased from Lawson HIS (best price I could find on the net).
Nett £84.95 Incl. £99.82 Link
http://www.lawson-his.co.uk/scripts/pro ... BIERH-750V
Delivery charge is a very reasonable £3.35. I also had a look at their clearance section and added a few items. Delivery charge was unchanged.
Specs ...
- # 2.0 joules impact energy.
# Max drilling capacity: masonry 24mm.
# Safety clutch to protect operator if bit jams.
# Rotation stop for light chiselling.
# Hammer stop for drilling and driving applications.
# Includes 13mm keyless chuck and adaptor.
# Twin bubble level for accurate drilling.
# Variable speed 0 - 1,100rpm forward and reverse.
# Livetool Indicator™ - Glows blue when plugged into the power supply.
# GripZone™ overmould technology for improved comfort with a positive grip.
# We supply this ERH750 with 13mm keyless chuck & adapter, 3 x SDS Drill Bits, 1 x flat chisel, 360° auxiliary handle, depth stop, carry case.
# PLUS FREE Ryobi fleece jacket (extra large only).
Ordered Friday. It arrived today.
Haven't yet had the opportunity to use it but I'll add to this thread as I do.
It comes in the usual glossy sleeve...
Dead link removed 06/10/2014
Inside there's the hard case...
First impressions? It's a L o n g Drill, but that's SDS for you. It doesn't have the Tubular Housing that some have coming down from the main barrel. Some of these I would say are shorter.
Weighs in at a healthy 3kg.
The 'Grip-Zone' mentioned on the Glossy Box, is actually a good idea. Initially able to grab the drill with fingertips and feels very secure, should help pick up when in awkward situations. A feature I'm sure we'll see on others soon.
One short coming that is immediately apparent is the Forward/Reverse switch, I'm not confident it will/would survive rough handling which in most cases an SDS is going to get, just feels a little flimsy shame as it's ideally situated and will no doubt get used.
Oh The fleece is a good quality one made by PortWest, I’ll picture it later. No one else was offering the Free fleece or a better price.
Jaeger.
