outside adhesive advice??
bgatty68
Has thanked: 21 times
Been thanked: 5 times
Post by bgatty68 »
I have just built a porch and have now got to tile the step (the porch is fully open, no windows etc) and i was wondering the best type of adhesive and grout to use outdoors, the tiles are quarry tiles, any advice would be welcome, I know BAL is a good make but not sure about outside.
:scratch:
Site Admin
Has thanked: 1012 times
Been thanked: 918 times
As long as you use a good waterproof adhesive for outside it should be ok, just make sure you don't use a trowel with deep notches, as I believe it is the trapped air behind the tiles that can cause problems outside.
bgatty68
Post by bgatty68 »
thanks UHM :thumbright: , i got a 3mm, 6mm and 10mm notched trowel, so i will use the 3 mm trowel then, should i go to a tile specialist shop for the adhesive or would something from Wickes etc be ok :scratch:
EJJ150847
Has thanked: 35 times
Been thanked: 188 times
Post by EJJ150847 »
I think a solid bed of adhesive is best for outside, a UHM says as long as the adhesive is marked as suitable for outside use it should be OK.
John
bathstyle
BANNED
Post by bathstyle »
Depending on the size of the tile; go for either a thick bed solid bed, a thin bed solid bed or if you have a very small tile then go for a solid bed tipped trowel.
bgatty68
Post by bgatty68 »
thanks to all of you for the advice, have bought a waterproof adhesive from wickes and will be tackling it this week, when all porch is done will put pics on the Gallery :thumbright:
