Lighting problems when trying to put up a spotlight
Locked
thesaint
Post by thesaint »
I've just moved into a pretty old house and I have a question about the wiring coming out from the light in one of the bedrooms. Apologies if this is a daft/obvious question but I'm a bit wet behind the ears with electrics!!
The spot light I'm trying to put up has the standard 3 wires as expected but there's 4 coming out of the ceiling (red, black, blue and another!). I'm told that I should twist 2 of them together to make the 3 that go into the spotlight.
Is this correct? Which 2 would need to be combined?
Problem is the current adapter doesn't fit into the housing of the spot - and I'd rather not make the hole in the ceiling bigger so it does!
Any help would be appreciated!
Thanks.
Site Admin
Has thanked: 1012 times
Been thanked: 918 times
These questions are never straight forwards.
Is the fourth wire a bare wire or is it sheathed with green and yellow sleeving?
Do any of the other wires have coloured tape on them?
I can't answer your question, but if you answer these perhaps someone else can do :wink:
sparkydude
Has thanked: 2 times
Been thanked: 149 times
Post by sparkydude »
Can you post a picture of the oldl ights connections, and perhaps the switch wiring aswell, then will be able to help you
Nick
thesaint
Post by thesaint »
will do - thanks for looking.
there's a red, blue, black and yellow/green - all sheathed.
thesaint
pics - finally
Post by thesaint »
struggling to get pics due to the upload limit on pixel size. i'll keep trying.
sparkydude
all sorted now as i am sure the saints will confirm
Nick
Locked
Return to “Lighting”
