Cutting tiles
wombleuk
Cutting tiles
Post by wombleuk »
just got myself a B&Q diamond water tile cutter (aka Plasplugs compact).
I've seen photos that show it cutting slots and square holes in tiles, but the instructions don't show you how to do it.
Neither does the very good instruction page and video on this site.
So, does anyone have any experience with one of these and can tell/show me how to do it ?
thanks,
Graham
tim'll fix it
BANNED
Post by tim'll fix it »
to cut out a section of a tile
cut slots from the edge at about 5mm apart then just snap off the bits you dont want
wombleuk
Post by wombleuk »
Thanks, that simple eh ?
I assume you should score across the slot prior to snapping it off ?
(can you guess this is my first time?)
How about a square hole in a tile for say, around a light switch ?
thescruff
Has thanked: 360 times
Been thanked: 3735 times
Post by thescruff »
To cut a square hole in the middle of a tile you will need a tile saw.
EJJ150847
Has thanked: 35 times
Been thanked: 188 times
Post by EJJ150847 »
wombleuk wrote:Thanks, that simple eh ?
I always score the cutting line as well as marking with a pencil, I find it leaves a neater edge. Bit like when you cut worktops the cut edge doesn't chip!
For square holes as said before a hole saw and tile saw is required, to square off the hole, rough edges can be dressed with a tile file.
Or drill a hole in each corner then use the tile saw along the scribed line, always try a cut on the down stroke away from the glazed surface.
John
Site Admin
Has thanked: 1012 times
Been thanked: 918 times
<embed src="http://www.ultimatehandyman.org/flvplayer.swf" quality="high" width="450" height="367" name="VideoPlayer" type="application/x-shockwave-flash" pluginspage="http://www.macromedia.com/go/getflashplayer" flashvars="file=http://www.ultimatehandyman.org/uploads ... r=0xFFFFFF" wmode="transparent" border="0"></embed>
Slugster
Post by Slugster »
Now that was just showing off...
Nothing you do is a waste of time - especially if it can be used as a bad example by others...
bathstyle
BANNED
Post by bathstyle »
........very difficult method of cutting a square out of a tile.
Only-Me
Been thanked: 3 times
Post by Only-Me »
Thats a soft clay tile Chez...............more difficult with a hard Porcelain
