circular saw blades
fin
Has thanked: 32 times
Been thanked: 807 times
circular saw blades
Post by fin »
ok i obviously need a new blade in my circular. but for now will a spare blade from my chop saw do? or will i risk burning the machine out?
saw is an elu with 216mm diameter blade. the spare blade is from my 701 chop saw and is a series 60 dewalt blade with a negative rake design
the blade that was in my circular is totally goosed
chippymike
Has thanked: 16 times
Been thanked: 9 times
Post by chippymike »
wouldn't bother mate get yourself a new trend blade or freud blade
fin
Post by fin »
ok ta for the advice. actually the blade i took out the machine is a negative rake design aswell having compared the 3 i have there all like that. cutting performance was pretty crap. guess its due to the blade design partially. ill sort a new blade for it asap
Griffin
Post by Griffin »
It could just be that your blades need sharpening, check for burning on the sides of the teeth. Negative rake blades are those multi material type blades you can use on wood and aluminum, generally they aren't as good in timber as a positive raked blades.
