tiling backerboard
mac321
tiling backerboard
Post by mac321 »
Hi all
Maybe you can assist/advice with a query regarding backerboards?
I am removing bathroom walls (currently nasty tiles over old plasterboard) and will be completely retiling using 60x30 tiles of over 20 KG per M2.
I am considering mounting HardiBacker board (12mm) onto the existing studding and then tiling onto that.
Question is: Is Hardibacker the best to use or is there a better alternate, considering performance and cost?
Any tips/area's to watch for if I do use Hardibacker?
Many thanks
M
Site Admin
Has thanked: 1012 times
Been thanked: 918 times
I have never personally used it, but it is supposed to be as good as aquapanel. Tile backer boards can carry more weight per square metre than most other substrates, just make sure that you fix it as per the manufacturers instructions :wink:
Mooncat
Has thanked: 81 times
Been thanked: 72 times
Post by Mooncat »
I have used it, it's much stronger than plasterboard but much harder to work with. It isn't as flat so I've used more adhesive.
mac321
Post by mac321 »
thanks guys.
looks like oodles of backerboard sheets for me today then.
once again, cheers
handyman
Has thanked: 6 times
Been thanked: 11 times
Post by handyman »
get them out of wickes..........20% off everything vouchers in the papers
Is it a bathroom? If so, have you considered tanking the shower area?
