glued wood joint
- BANNED
- BANNED
- Has thanked: 736 times
- Been thanked: 2342 times
heeelllooo topura01
the joints may be formed off mortice and tennons 'dowels or buiscuts
if its formed with mortice and tennons there could be nails screws or dowels as well as the glue holding the joint tight
they can be obvious or on the blind side
and on spray finnish furniture may be completly invisible
the joint could even just be butted up with screws and metal plates and dry locating dowels
i take it youve had a good look!!!
- Professional Carpenter
Mangrove adhesive is made using tannin from bark.. it isn't a good glue due to the size of the molecules, they cannot move freely about their backbone
So inherently the glue becomes brittle. also not good in wet areas. so thats two lines of attack for you to persue
If it aint broke...... don't fix it
chippysmith wrote:Mangrove adhesive is made using tannin from bark.. it isn't a good glue due to the size of the molecules, they cannot move freely about their backbone
I think that means 'hit it' in English.
