BATHROOM CEILING SPOTLIGHTS
Locked
trickdick
Post by trickdick »
Hi
New member to the Forum here.
We're having our bathroom re-done shortly. I would like to have a sunken ceiling spotlight above the shower cubicle.
Can anyone recommend good makes to use - or alternatively, makes to avoid?
Thanks for your help
sparkydude
Has thanked: 2 times
Been thanked: 149 times
Post by sparkydude »
Hi, try looking here for some, these will require a transformer to operate them as they are 12V , but provide a much cleaner light than a normal lamp.
http://www.tlc-direct.co.uk/Main_Index/ ... index.html
If your having your bathroom re-done by a builder, make sure his sparks is Part P registered and gives you a certificate for the work and also advises the local councl of the job.
Nick
Locked
Return to “Lighting”
