What are these holes
skiking
Been thanked: 4 times
Post by skiking »
I've just had some oak skirting delivered and there are some holes (circled) in the planks that don't seem to have been caused by nails IMO.
Could this be wood worm, if so, is it safe to use this wood :scratch:
marc1106
Has thanked: 4 times
Been thanked: 49 times
Post by marc1106 »
they do look like worm bores! couldnt tell you if its old or fresh though!
IF IT WERE EASY ITD B BORING!
skiking
Post by skiking »
Is this something I need to worry about i.e should I take it back to the timber merchants ?
Hoovie
Borders Bodger
Post by Hoovie »
That does look very much like the woodworm holes I have in my house, except I would have expected more holes (in all my woodworm there many more boreholes and a lot closer together)
joiner_uk
Been thanked: 6 times
Post by joiner_uk »
That timber definately needs exchanging because of the holes. Chances are slim that woodworm is inside but you never know!
Here is some useful info on woodworm
skiking
Post by skiking »
Thanks for the info.
The holes generally appear at the end of the lengths so I may be able to cut off this area. I'll have to inspect the longer lengths a little closer.
carhartt kid
Has thanked: 3 times
Post by carhartt kid »
Take it back!!! Theres no way I would risk introducing wood boring beetle or wood worm to my house or any job I do!
I've had plenty of wood delivered over the years that looks like this. I send it back every time! Don't accept any excuses like "oh, its been treated" or "it comes in to us like that" or "its perfectly natural" or "The bugs get killed when its kiln dried" BULLCRAP
Give TRADA a call for specialist advice! Most suppliers accredited by them, so they're always interested to hear about companies spreading parasites!
http://www.trada.co.uk/index.html
You wouldn't buy a brand new car off the forecourt of a main dealer, with rust all over it would you!!
http://www.carhartt.com/
skiking
Post by skiking »
sh*t :shock: :wtf:
Cheers CK
If I cut off the areas where the holes are what are the chances that the beetles are still within the remaining wood. I've actually cut off the offending parts as off cuts, as well as cutting the lengths down to size so I can acclimatise the wood in the relevant room so I may have issues in taking it back :roll:
Gadget
Jack Of All Trades
Has thanked: 344 times
Been thanked: 342 times
Post by Gadget »
Just tell them you only noticed the holes after you made the cuts!
By eck! ©
carhartt kid
No panic skiking.
Option 1.
Take it back and say you cut it up and during this you found the worm holes! Stamp your feet and growl till they replace it and give you a huge discount. They hate it when you do this and there are other customers about. Try and take it back when thay are really busy!
Option 2.
Just run over the pieces you have cut with a hoover or dyson etc to find any holes you missed. You can cover your back by either getting some woodworm or beetle treatment like Cuprinol woodworm killer. Slop a load on the unseen sides of the timber and just one coat on the front. It will change the appearance a bit. A bit like oiling it or staining it. But if you're going to give it a finish then this won't matter.
I'd take it back personally!
skiking
Post by skiking »
TBH its not the beetles I'm worried about, its my dodgy plastering :roll: :oops:
I'll inspect closely tomorrow and decide then but the timber merchants I used are quite good but it was a third party company that made the skirting for me ::b and it wasn't cheap :shock:
carhartt kid
Even more of a reason to give them a call!! Best of luck!
