Hi all - I'm new and have to confess to a disaster.
I laid my new bathroom floor beautifully - Brazilian slate tiles. The problem is, I did not wipe up the excess grout. It has dried rock hard. If I attack it with a blade I will scratch the surface of the slate.
There is a lot of excess grout on every tile. How can I remove it without damaging the slate?
I appreciate it's a stupid mistake but I can't be the only one ever to have made it - there must be a solution.
Thanks in anticipation
Help - removing dried grout from slate floor tiles
This might do the trick-
http://www.extensive.co.uk/product.php/ ... nt-away-1l
I would use the contact form on their website before buying and make sure you get the correct stuff
http://www.extensive.co.uk/contact.php
- DOMINOSEATER
JUST A QUICK TIP I LEARNED WHILE DOING SLATE TILES ETC IF I EVER LEAVE GROUT OR ADESVIVE ON TILE AND IT GOES ROCK HARD THIS IS WHAT I USUALLY DO AND IT WORKS A TREAT.
GET A BUCKET AND FILL IT WITH BOILING WATER ADD A FEW DROPS OF FAIRY AND USE A GREEN PAD OR A DECK SCRUBBER AND ALL WILL COME UP.
THE BOILING WATER BREAKS DOWN THE GROUT BACK TO A POWDER LOL
