diagonal tiling
- Has thanked: 4 times
- Been thanked: 49 times
add 50% to your normal floor tiling charge as you will be running back and forth to the cutter more! if it were me id be 45 pmetr +22.5= 67.50 per mter X 13= 877.5 bu that would include addy and grout. but alot woul also depend on type of tile and what its going down onto and where you are in the country affects the rate also!
IF IT WERE EASY ITD B BORING!
thanks for your help guys.would have to overboard it first although i will prob use ci matting instead cupboards to cut round cuts into,or thru 4 doors + runs from front to back door.porcelain tiles need sealing.grey and beige alternate.the abode is in yorkshire.
done a bit of diamond tiling b4 some cuts give you brain ache
any chance of a new estimate?
