Super glue
rs232
Has thanked: 3 times
Super glue
Post by rs232 »
I attached something to a tile in the bathroom using super glue some time ago.
Now I'd like to remove it, any good advice on the procedure? May be using alchool?
I really don't want to damage the tile
Thanks!
Geewizz
Has thanked: 7 times
Been thanked: 51 times
Post by Geewizz »
Do you have access to a time machine?
Phil
Advise rhymes with rise. Advice rhymes with rice.
rs232
Post by rs232 »
Yes, but I will have to change the batteries :?
Geewizz
Post by Geewizz »
You're unlikely to find a solvent for the glue but you could check with the manufacturer if you can remember what product you used.
Without knowing what you stuck to the tile it's difficult to advise you on what mechanical methods you could attempt. Do you have a photograph? That would help determine what tools you could get in with and a method for removing it.
Phil
Has thanked: 735 times
Been thanked: 2340 times
use superglue release :thumbright:
http://www.screwfix.com/prods/39759/Sea ... elease-20g
somtimes soaking in warm soapy water for a few days will work :scratch:
marc1106
Has thanked: 4 times
Been thanked: 49 times
Post by marc1106 »
Or failing Big-alls sugestion soaking it with acetone (nail polish remover) will do the trick, but be cautious as it may stain porous tiles!
IF IT WERE EASY ITD B BORING!
