no mate, 1 wall at 7 2 sides at 3.5 and the back is a solid breeze, rendered wall.big-all wrote:my bwain hurts
2 walls 7m + 2 walls 3.5 = 21m!!!!!
build a shed from sleepers
- Has thanked: 736 times
- Been thanked: 2341 times
cheers i understand nowjonny18 wrote:no mate, 1 wall at 7 2 sides at 3.5 and the back is a solid breeze, rendered wall.big-all wrote:my bwain hurts
when i built my shed more than half the £700 wood costs where the roof and floor but i did use 18mm ply l o l
the sides where 5"tounge and groove shiplap pressure treated
its a 10x12ft shed which incidently =13.2m very close to your 14m the txg cost around £250
- thescruff
- Has thanked: 360 times
- Been thanked: 3735 times
good photos man.
big-all wrote:cheers i understand nowjonny18 wrote:no mate, 1 wall at 7 2 sides at 3.5 and the back is a solid breeze, rendered wall.big-all wrote:my bwain hurts
- Tryanything
- Been thanked: 4 times
Suggestion for corners and any internal walls
Sleepers will probably be waterproof already but a coat of old engine oil
and cresote mix would'nt go amiss
Nice big mastic joint between each sleeper and joints and all tosh nailed
together from inside
- shed walls.jpg (13.57 KiB) Viewed 2149 times
thanks, will the engine oil or cresote smell permenantly or just while it drys, and what are tosh nails..Tryanything wrote:Suggestion for corners and any internal walls
do you have a program for drawings like that. i could do with a good program to design work projects for customers.
thanks
- Tryanything
Tosh nailed
Any type of nail just toshed in at an angle
The sleepers are going to stink anyway, but after a good summer (ha ha) they should be fine
The program l use mostly is "Draw" in MS Works
- Noname.jpg (7.64 KiB) Viewed 2130 times
