Floor tiles on wood particle flooring
The "floorboards" of my modern house (built 2000) are some sort of large sheet particle board. I want to lay ceramic tiles on my bathroom floor and want to know whether I can tile direct on to this or does it need treated in any way. What sort of adhesive and grout should I use? The present flooring is carpet.
Sorry no. The whole of the upstairs is floored out with this stuff, so it goes under the partition walls. The builder was Taywood, so this is obviously standard procedure at that time.
- Bludall
- Forum Chatterbox
- Has thanked: 39 times
- Been thanked: 5 times
We have a 1995 house, the flooring is grade 5 WBP (waterproof and boil proof ply) over polystyrene sheeting and concrete beams.
We had the same problem but only because the floor Weetabixed after a bath waste leaked. We replaced it with WBP 25mm 8 x 2 t&g sheets and have Aquapanel to tile on. Aquapanel is a cementitious reinforced board that is rigid enough to lay tiles on. You need a flexible fast set adhesive though that will allow for movement in the floor.
Ask the guys they'll tell you in more detail, I'm just a mere girl! There's a link for the Aquapanel.
http://www.ultimatehandyman.co.uk/tilin ... floors.htm
Failure means you just didn't get it right yet!
Louise
Louise
Guess this "floorboard" stuff must be waterproof as can see that there have been some leaks from the bath in the past and the "floorboards" are still OK. Does this mean that the floor tile adhesive will not stick to it?
This seems a bit like overkill if the original base is already waterproof. Housebuilders aren't going to put in floorboards that disintegrate the first time there is a leak - in fact thinking about it we have already had a major leak from the other bathroom and although it almost brought the ceiling down, the floorboards were OK.
- thescruff
- Has thanked: 360 times
- Been thanked: 3735 times
Re: Floor tiles on wood particle flooring
Dream on Catweasel.catweasel wrote:This seems a bit like overkill if the original base is already waterproof. Housebuilders aren't going to put in floorboards that disintegrate the first time there is a leak - in fact thinking about it we have already had a major leak from the other bathroom and although it almost brought the ceiling down, the floorboards were OK.
House builders use the cheapest stuff they can get their hands on.
