how long to dry
juandan
how long to dry
Post by juandan »
hi, I tiled my bathroom wall over 48 hours ago, I was taking some of the spacer's out to get it ready for grouting but some of tiles come off the wall, the tile adhesive is still soft, the manufactures instructions says grout after 48 hours, mind you it is cold in my bathroom could that affect the drying time? I'm using Cerafix tile adhesive for B&Q
Site Admin
Has thanked: 1012 times
Been thanked: 918 times
It should be hard by now :shock:
I'd leave it until you are certain that the adhesive has gone off.
Only-Me
Been thanked: 3 times
Post by Only-Me »
Is that the cement & grout in one :scratch:
If so.......about a week to go off :roll:
darrenba
Has thanked: 104 times
Been thanked: 490 times
Post by darrenba »
What size are the tiles? Ready Mix adhesive won't set properly/quickly with large format tiles.
jozeffo
Has thanked: 45 times
Been thanked: 272 times
Post by jozeffo »
Check the tub. If the walls are too cold, turn the heating on full. Some say 15 degrees minimum. if you have used a flat bed rather than a notched trowel, drying may be a problem at low temperatures
LouLizR
Post by LouLizR »
A number of factors affect drying times:
temperature
type of tile - ceramic or porcelain, etc
the substrate, ie wall
adhesive used
The wall has to be perfectly dry to tile on to. If it has been wet, give it a good week to dry out, with the heating on. Use a 6mm notched trowel and try and make one consistent pass with the trowel on the wall.
If using tiles other than ceramic, then drying times will probably be greater, esp porcelain.
Never grout until you know your adhesive is dry - put a heater in the room.
Just been using 16hr adhesive, with ceramic tiles, which hadn't set after two days - temperature was the issue there as no working heating in the new development.
