FITTING FLUSH HINGES TO EXISTING KITCHEN CUPBOARD DOORS
Locked
catswhiskers43
Post by catswhiskers43 »
Could anyone advise how to fix these flush hinges as I am a MERE woman...lol
Site Admin
Has thanked: 1012 times
Been thanked: 918 times
Hi and welcome.
Are the holes already drilled in the doors?
If not take a look at this-
fitting-kitchen-door-t4850.html
Some of the pro's will be on later and they may have some more advice :wink:
Rich-Ando
Pro Tradesman
Has thanked: 135 times
Been thanked: 304 times
Re: FITTING FLUSH HINGES TO EXISTING KITHEN CUPBOARD DOORS
Post by Rich-Ando »
catswhiskers43 wrote:Could anyone advise how to fix these flush hinges as I am a MERE woman...lol
and don't ever do yourself down, if us blokes could do half the things you women can do, we wouldn't go to work to get out of doing them :wink:
marc1106
Has thanked: 4 times
Been thanked: 49 times
Post by marc1106 »
there should be 2 35mm holes aprox 6mm in from the edge of the door!
the large recess part of the hinge sits in those and then you use 2 12mm screws to hold each hinge in place!
the "butterfly" plate side of the hinge screws into the cabinet into hole that are paired and set aprox 35mm back from the edge of the cabinet!
heights of those are dependant on where the cabinets came from so offer up the door with the hinges on if its not obvious! screw them into place!
Slot the door part over the cabinet part locating the clip or screw( depending on where the hinge came from)
:thumbright:
IF IT WERE EASY ITD B BORING!
Locked
Return to “Kitchen Fitting”
