Marc1106 DO NOT TILE ONTO A BACKING PLASTER if your gonna use bonding or hardwall you should get it skimmed, and remember a skim coat or a float and set wall will only carry aprox 20kg Per meter sq so check the weight on a box! before sticking em up!
I always thought a rougher plaster would give better adhesion for tiling and I understand your view that the rougher plaster will dry out the adhesive too quickly . I looked at BAL website as I use their gear often and they suggest 2 coats of SBR bond diluted unless the plaster is very smooth in which case it should be keyed first.
I would therefore use undercoat plus SBR in futue as I think it would give the strongest adhesion. My worry would be that Skim does not bond as well to substrates as bonding or hardwall do.
http://www.bal-adhesives.co.uk/technical/faq
Asked before but PLEASE HELP ONCE MORE lol!
- Has thanked: 45 times
- Been thanked: 272 times
- cantbethathard
- cantbethathard
Yeh was wondering what was a good quote etc. I'm going to ask him what he would do? If he says sand then I'll sand to save some money so hopefully all he'll need to do is plaster the board I've fitted then tile!
Any idea what the average hourly charge? Or charge per metre or whatever they charge at lol!
Been given one idea by one of the boys on here but more gratefully received so I don't get done! lol
There is no point plastering the board, it will be better left as you have replaced it.
Where are you in somerset? Near WSM, my aunt pays about 100 a day for a local lad who she thinks is OK. A busy professional may be 150 but will probably not take all day so be inquisitive and you should end up with a fair deal.
- cantbethathard
Ok thanksjozeffo wrote:There is no point plastering the board, it will be better left as you have replaced it.
- cantbethathard
