tiling in splashback in kitchen
Hello all new here and just starting to begin tiling the kitchen splashback. We have a double brick home. I have removed the old tiles over the sink. The tiles seemed to come off fairly good, without too much of a mess. The concrete/brick wasnt damaged much at all. My question is, how smooth does the surface have to be before applying new tiles. Do I have to plaster the concrete to get a smooth surface? I would think that the tiles would adhere well to a rough surface, maybe i am wrong. Any advice/suggestions would be greatly appreciated.
thanks
thanks
- manchestertiling
whippee, you should be aiming for a flat surface to tile to, the flatter the better the finish will be.
Ideally skimmed, left to cure & primed with an acrylic primer, you should never use adhesive of any type to fill holes.
There are other things you could use like BAL Quickset render, sets in 2 hours & suitable for most substrates but will obviously be premium price.
- manchestertiling
Tile adhesive is as said Craig - tile adhesive, there are plenty of alternatives to tile adhesive for filling holes.handyman wrote:why should you not use a bit of rapidset to fill a small area ?
Obviously not a full skim, just to even off a bit of tile removal damage, where a full skim would be way OTT.
and
have you used quickset render? Any good?
Let also look at it this way too - say a good quality 20kg bag of adhesive is what? Anywhere between £10-£20, a good quality 25kg bag of plaster is say £5, work it out!
BAL Quickset render is great stuff easy to use & very quick drying, applied & tiled the day after, unlike plaster having to wait recommended 4 wks before tiling, not sure of cost as I got freebie off the BAL techies on a site visit few weeks back, will probably be pricey though, to be expected from BAL, premium brand - premium pice
