POLISHED PORCELAIN FLOOR TILES
why to you have to seal the above tiles ,just asking because in b&q they tell you to seal before fitting including edges and all cut edges surley if you did this when you come to grout you would have problem with grout not adhering. thank you transit boy
- manchestertiling
- manchestertiling
From my experience transitboy, usually porcelain itself needs no sealer, water ingression stands at about 0.05% which is hardly anything, but the polishing process of the tile opens up micropores which themselves, especially on floors fill with dirt & water & discolour or stain the tile.
An impregnator sealer will fill the micropores up first preventing this. My advice is always to try a test piece first and that will prove beyond any doubt if they need sealing.
I noticed when B&Q first had their £6 a box cheapo porcelains there was no sealing advice on then, now there is.
Use a dry wipe marker, water, red wine, ketchup etc leave for 10 mins & wipe off to see if it leaves a mark, if it does then seal.
Paul
- manchestertiling
sealing etc
Sorry to tell you this but the B & Q tiles are not very good quality. Theres a reason why they are so cheap !! --- they stain easily (even most seals smear over the tile )
I have had more than a dozen people come into our place over the past year about problems with sealing and staining.
These tiles are mostly from China. The porosity is higher than average. Often they have been mildly waxed to protect in transit. This needs to be washed off with mild cleaning liquid -- ie fairy liquid. The tiles then have to be sealed with (to stand a chance) a dedicated Pol Poec sealer such as LTP mpg polporc sealer. Keep strictly to the instructions.
The main problem is, that even the best sealer will not be so effective on a sub-standard tile - sorry to be the bearer of bad news
- manchestertiling
Re: sealing etc
Couldn't put it better myself MOKMan of Kent wrote:Sorry to tell you this but the B & Q tiles are not very good quality. Theres a reason why they are so cheap !! --- they stain easily (even most seals smear over the tile )
Good advice & true about bnq, if something is cheap there is a good reason! Most decent porcelain tiles will be bnq's price x 4.
A good tiler though will make bnq porcys look expensive ones
Paul
Thanks for your replies, there might have been a misunderstanding.
The tiles I am laying are Wickes own.
They got in touch with the manufacturers and were advise to tell me to clean it off with talcum powder...... never heard of this!!!
I tried it and it never worked, also tried washing up liquid with no avail.
I am a little worried as I normally only do ceramic and porcelain and not the polished.
I also usually keep clear of natural stone, so this is the first job where I will have to seal.
Sorry to ask so many questions
Transit boy
Transit boy
- manchestertiling
