Bathroom fitters
DIY_Johnny
Mr. Grumpy
Has thanked: 25 times
Been thanked: 109 times
Bathroom fitters
Post by DIY_Johnny »
Hi chaps, I am laying the floor for my bathroom. I have used 18,, ply on top of joists and noggines at 300mm centeres. I know I was supposed to use 25mm ply but was hard to get. anyway floor seems rigid.
I will be tiling the floor soonish but was wondering if its worth using a tanking kit or matting. This is for a rental property and every place I have every seen the tenants always leave a load of water on the floor
When you guys rip out bathroms do you often find that water has got down below the tiles?
manchestertiling
Post by manchestertiling »
Not unless the tiling was done poorly in the first place john but if you have any doubts about it go ahead & tank it
Paul
DIY_Johnny
Mr. Grumpy
thanks Paul,
:thumbright:
manchestertiling
Make sure you use a premium flexible adhesive John with only going with the 18mm ply, you may still get some movement yet :thumbright:
Paul
Man of Kent
bath floor
Post by Man of Kent »
Agree with MT
Tanking not really necessry. I tend to do it only in shower or wet room situations.
Re the adhesive, again I agree. A premium one part flex will prob suffice although in the past , if there is a little doubt, I have used the extra flexible 'Ultimate flex' from Granfix. Bit expensive though -- £45/50 ?? to do about 4 sq mt --- mind you , bal ordinary flex prob costs that anyway !!
DIY_Johnny
Mr. Grumpy
cool, I have always noticed in any rented house I have been in tenants leave pools of water on the floor which I was wondering if it makes it way down through the tile grout.
Is tile grout total impervious to water?
manchestertiling
I wouldn't say 100% totally impervious John, most of the manufacturers say water resistant, which is a splash here & there that can be wiped up within a reasonable amount of time, they don't say waterproof! Unless you use an epoxy grout which will guarantee 100% waterproof
Paul
DIY_Johnny
Mr. Grumpy
Cheers Paul,
I have used aquapanel so am going to tank than anyway as water seeps through that pretty quick. Will do the shower area only
Actually just on this topic, I actually D'n'D the aquapanel and secured it with with 10mm Fisher plugs and screws. (I know you are supposed to frame fix aquapanel but just didn't have the room for a frame)
In any case, I noticed that when using direct bond method with LOTS of adhesive, the aquapanel was well suck to the wall. Mechanical fixing afterwards seems a touch unnecessary but went and did it anyway.
manchestertiling
Best you did John, never unnecessary & the right way to do it
Paul
