Tiles on timber
- Mooncat
- Has thanked: 81 times
- Been thanked: 72 times
Tiles on timber
Mrs M wants a tile-topped plinth to go around the bath, under the rim. 4" x 2" CLS laid flat, lap joints at corners, with substantial supports under. As it won't get soaking wet, am I safe in sticking the tiles straight onto the timber, or should I use tilebacker board on top of the timber? I have built a similar plinth, using timber/MDF , and had no trouble with it over 15 years.
- cheadle_plastering
I wouldn't tile onto the timber mooncat, would go with the TBB just to be safe more than anything...although my old house had a tiled panel & 100mm plinth around the top, tiles were fixed onto standard PB & it had been in for around the same amount of time with no problems.
Paul
[url=http://www.cheadleplastering.co.uk]Cheadle Plastering[/url]
- manchestertiling
