floor Tile cutter
- Has thanked: 1 time
- Been thanked: 2 times
floor Tile cutter
will be doing a floor with bnq tiles £10 a metre gray-black type, 10 mill maybe, whats the best cutter i should buy to do the job, for diy use, and how many cuts does a blade last?
any tips as to cutting tiles, and around rads whats the best method?
also fix full tiles, then cut next day, and lay cut tiles? to edge
Do you pva a ply deck first? before adhesive
cheers
cheers
These pages might help-
tile cutting
floor tiling
PVA & tiling
tile cutting
floor tiling
PVA & tiling
http://www.toolventure.co.uk/Brands/Rub ... p3065.aspx
ceramic, not bought yet, would the above be ok, was looking at 600 watt electric £100, would rather buy then hire, but if it wont do the job, will have to hire, £100 is top i would pay
cheers
cheers
