CONNECT PC TO TV
CONNECT PC TO TV
I have just bought an 32" lcd tv but i relised it has no vga socket for me to connect my tower to it, is it possible for me to connect it via hdmi lead as i have that socket on the back of my tower, or is there another way.
Thanks.
Thanks.
- AntonyRBrown
You can covert pretty any signal nowadays most just with cable adapters rest you will need a conversion ancillary
Most popular
DVI - HDMI
VGA - DVI
VGA - Component/Composite
Like the last user said what model of TV do you have or just take a picture if you can and what options do you have on the graphics card ( Is it External or on-board ) etc
Antony
Most popular
DVI - HDMI
VGA - DVI
Antony
- AntonyRBrown
get one of these dont goto maplin though there rip-offs
http://www.maplin.co.uk/module.aspx?Tab ... &U=Strat15
and a hdmi cable, set the resolution on your PC to 1280x720
I'm pretty sure your computer has DVI output
that will work
Antony
you also want the MALE converter so the prongs are on the adaptor, your computer DVI output is Female.
hope that helps
that will work
Antony
hope that helps
- AntonyRBrown
- Dan Robinson
I don't think your PC has a HDMI output - I am pretty sure GeForce 8's only had a pair of DVI connections.
I would take the tele back personally and get one with DVI or possibly VGA.
I think the HDMI connections can cause troubles because of their poxy encryption doodahs.
Kind Regards,
Dan Robinson - [url]http://www.jenningsheating.co.uk[/url]
If you give’m choices they'll give you grief.
- AntonyRBrown
look 2 posts up he said he dont have DVI connections, he has VGA connections it is onboard graphics. hence i need the Exact model numbers and i can tell him 100% what he needs to do... you can convert DVI - HDMI as they are exactly the same signal apart hdmi carrys audioDan Robinson wrote:I don't think your PC has a HDMI output - I am pretty sure GeForce 8's only had a pair of DVI connections.
HDMI's Encryption HDCP is only going to be an issue on HDTV set top boxes (sky/cable) and most PC's setup with Windows Media Center.... and if the latter is the case the pc would have a hdmi connection on it..
- Dan Robinson
I shall bow to your great knowledge and perform in recompense for not paying attention to the "onboard" bit.
I didn't realise the video signals are the same...
Personally I think all this hi-def stuff is a load of unecessary twaddle.
Kind Regards,
- AntonyRBrown
- Dan Robinson
A bit like the next Daz getting whiter whites than that last version that required singlasses to look at
I can't say I can tell the difference between the VGA and DVI images on my rig...
I suppose there is a marked difference between MPEG2 abd MPEG 4...
and 128kps audio is dire - 192 is fine...
Kind Regards,
- AntonyRBrown
see you wont see a difference unless there is a format being played on the TV or the size.. take a 92" LCD that is HD compliant. plug a PC playing random Videos on it and use VGA or composite.. then plug the Same PC into composite or DVI/HDMI and you will notice the difference
Audio is the same ... Bigger speakers on a lower sound bit and the volume is up you gonna hear distortion.. add thicker cable and a better quality speaker the sound s better..
all signals start at 1 position and have to finish at another position
lets say A - C
B= what that signal has to travel through to be converted to what we see as a viewable or hear as an audible format
if B isn't good enough then C is always going to = crap
lets say A - C
