beware of net curtains
Diy disaster stories in this forum please, Tradesmen disaster stories are also welcome in here!
Locked
tomm
Post by tomm »
Another incident with the blow torch-
I was once soldering a joint below a radiator which was underneath a window. I got distracted and set fire to the net curtain, you would not believe how fast the damn thing went up!!!
When using a blow torch keep away fron net curtains and birds nests
yourweb
Post by yourweb »
You probably should of moved the curtains first before working on that.
Scrit
Pro Cabinetmaker
Re: beware of net curtains
Post by Scrit »
tomm wrote:When using a blow torch keep away fron net curtains and birds nests
I'm just trying to figure out what sort of houses the OP works on that have birds nests in the plumbing :shock:
Measure twice, cut once - except fingers!
Gadget
Jack Of All Trades
Has thanked: 344 times
Been thanked: 342 times
Post by Gadget »
yourweb wrote:You probably should of moved the curtains first before working on that.
Sound advice!!.......... ::b
By eck! ©
Hinton Heating
Gas/Heating Expert
Been thanked: 9 times
Post by Hinton Heating »
I shinged someones towel last week, which hanging above the area i was working!
wrap round pipe lagging also goes up well!
Locked
Return to “DIY Disasters”
