Tiling over damaged filled wall
grgrant
Post by grgrant »
I am having a new bathroom fitted and removed two walls worth of tiles myself. Unfortunatly big holes (3mm deep but wide) appeared once the grout was removed. I have filled the holes with standard filler (some of the holes are 2 feet wide in diameter). The wall is flat witha few minor bumps where the filler is slightly uneven.
Will a tiler be able to tile over this wall?
Excuse my ignorance as im not very handy :)
Geewizz
Has thanked: 7 times
Been thanked: 51 times
Post by Geewizz »
Yes, he will. If there are any bits that are not flush then he will sand them off or the adhesive will take up the slack. Your tiles will stick to the filler. Your only worry now is that you managed to get good adhesion between your filler and the wall.
Phil
Advise rhymes with rise. Advice rhymes with rice.
m3 fitter
Tiling Expert
Been thanked: 14 times
Post by m3 fitter »
leave the prep, as the tiler will advise on the best way forward
AAJ Tiling
Post by AAJ Tiling »
use a 2m straight edge say like a level put it on over your walls making note of any bumps or dips all should be with in a 3mm tolerance to keep yer tiler happy
http://www.aajtiling.co.uk
