how to get grout off the tiles
- Has thanked: 34 times
My wife been cleaning the tiles and soon it is dried, the cloudy effect appears on the tiles and she has had enough of cleaning the tiles for the past 3-4 days.
What is the beat way to remove this stuff quickly or is there something on the market which you can buy.
She has been using clean water and sponge. I left the gorunt for few days due to hot weather kids wanted to go to the theme park.
what tiles are they ceramic, porcelain???
imagine there the latter some porcelain needs to be sealed proir to grouting as the like to soak everything in.
if this is the case, carry on with the advice already given with plenty of elbow grease try also working samller areas i.e a m2.
your local shop could supply a cement grout remover. beware they can be acidic try on a small area as the can damage your tile and grout
http://www.aajtiling.co.uk
Thank you for your reply,
I have managed to remove it, but my grout line they are not vertical or horizontal in straight line, as there are some excess grout build up during the application of the Grouting.
I used the HG Cement Grout film Remover
My Tiles are Ceramics from B&Q.
- HG cement Grout film Remover.JPG (27.71 KiB) Viewed 2956 times
Tiling pictures and ensuite
I am attaching pictures of the tiling which i have done and fitted the Toilet, Towel rad, Basin.
Electric shower not connected yet, Architrave not fitted yet and the Shower Bi fold Door. It will be done at the Weekend.
There are grout line which has been over filled and over flow, as they look like a wide grout line.
- S8305052.JPG (57.63 KiB) Viewed 2931 times
- S8305053.JPG (99.17 KiB) Viewed 2931 times
- S8305054.JPG (91.92 KiB) Viewed 2931 times
- S8305055.JPG (95.63 KiB) Viewed 2931 times
- S8305056.JPG (106.54 KiB) Viewed 2931 times
- S8305057.JPG (100.96 KiB) Viewed 2931 times
- S8305058.JPG (104.11 KiB) Viewed 2931 times
- S8305059.JPG (99.49 KiB) Viewed 2931 times
- S8305060.JPG (94.84 KiB) Viewed 2931 times
- S8305061.JPG (88.36 KiB) Viewed 2931 times
- S8305062.JPG (104.05 KiB) Viewed 2931 times
- S8305063.JPG (100.36 KiB) Viewed 2931 times
- S8305064.JPG (104.72 KiB) Viewed 2931 times
- S8305065.JPG (98.71 KiB) Viewed 2931 times
- S8305066.JPG (97.39 KiB) Viewed 2931 times
- S8305067.JPG (91.32 KiB) Viewed 2931 times
- S8305068.JPG (90.87 KiB) Viewed 2931 times
- S8305069.JPG (97.33 KiB) Viewed 2931 times
- S8305070.JPG (90.71 KiB) Viewed 2931 times
- S8305071.JPG (92.74 KiB) Viewed 2931 times
- thescruff
- Has thanked: 360 times
- Been thanked: 3735 times
