If I take the hard drive out of a not working computer, and stick it in one that is, what would happen.
Both are on 98se.
Hard drives
- thescruff
- Has thanked: 360 times
- Been thanked: 3735 times
- dave.m
- Deceased 07-06-2012 R.I.P
- Has thanked: 13 times
- Been thanked: 318 times
Scruff,
You can do it, instructions here how to and also on setting the BIOS:
http://www.cybertechhelp.com/tutorial/a ... rive-win98
Is there something on it that you want, or is it just to increase storage?
Seems a lot of trouble for an old OS like 98SE.
dave
dave
- thescruff
I love 98se
Lots of reasons for wanting to keep it working.
I have an agfa photo scanner which you get drives for.
I have several programs which will only work on 98se, including a disc with thousands of old boilers.
The plan was I have two HDs in an old computer, and I was going to take them both out and fit the single HD from the defunct one.
- dave.m
It would not work like that, because the MB would not recognise the OS on the newer HD.
What you could do is to leave the master HD in the working computer so that you will have 98SE still on it and install the HD from the defunct PC as a slave drive.
dave
- thescruff
- Has thanked: 247 times
- Been thanked: 314 times
