Grout marks on tiles
- notsohandyman
I tiled my bathroom using a ceramic tile called Padova from Topps Tiles. The tiles have a matt finish to give the effect of natural stone.
Topps gave me a BAL grout to use and all was going well until I tried to get the grout haze off the tile surface. I followed the instructions and cleaned down as I went. I then went over the tiles with Fila Extra Strong Residue Remover (twice), as recommended by TOPPS, using cleaning pads but the marks will not shift. The bathroom is fully tiled, including the floor, which took me ages but now it looks a complete mess.
Has anyone out there got any suggestions? Someone I know suggeted using a brick cleaner but I'm worried about it damaging the finish on the bathroom suite.
Any help is appreciated. Many thanks.
NotSoHandyMan
- notsohandyman
Hi Panlid and thanks for your response.
Yes, I would cover the bath etc over but as it's recessed into the tiles along 2 walls, some of the acid is bound to seep through onto the surface no matter how well I try to seal the area. It's acrylic with a polished surface so I'd imagine that would be instant disaster!
I guess I'll have no choice but to try it if it's the only option.
Thanks,
Thanks,
NotSoHandyMan
Padova rings a bell. Are the tiles approx 450mm x 300mm? in a kind of natural stone finish with a dark brown backing and sides?
If so then I have done these very same tiles from Topps and they are a real nuisance.
It was a while ago now but I recall using Lithofin easy care, plenty of Hot water and some very abrasive cloths.
The problem I was getting was that every time you went over them they looked clean but when dry the grout residue would lighten up and show again.
Actually, thinking about it, I think I used some HG cement residue remover for calcareous tiles (less aggresive) as I had some in the Van.
- notsohandyman
Hi bstyle,
You're spot on, the exact same tiles and yes I'm experiencing the same thing. Clean them and they look fine for 20 mins or so but them the white powdery residue appears.
You mention HG cement residue remover. Is that it's full name and do you know if it's stocked by the large DIY stores or a specialist product?
I've spent months doing this bathroom from what was an empty shell. After all the work I've put in I'm pretty ticked off that such a stupid thing could spoil it!
Look forward to your reply - cheers.
NotSoHandyMan
It's not something that can be bought from a DIY shop, it's specialist stuff available at tile shops.
I would just keep plugging away at cleaning, use hot water and Topps tiles also sell an abrasive cloth set for about a fiver, use the most course cloth. I do sympathise with you, tile cleaning can be a real problem.
If it's any consolation, I used a modified grout because I had a travertine mosaic border which made the grout even more stubborn!
- notsohandyman
Just by way of an update, I thought I'd let you know how I've got on.
I went to a local shop and they suggested I try Spirts of Salt (carefully). So I bought a small bottle for £2.50, brushed it on to a small area at a time and washed off after 10mins and it's worked!
Mind you, only managed to do half the bathroom this weekend because this stuff is absolutely vile to work with, the fumes knock you sideways if you get a lung full so can't stay in the room for long!!
However, I looked at the link on the AT Stone website and I think I'll finish the rest with either Lithofin Cement Away or Builders Clean... and breath properly again!!!
The grout I used was BAL Superflex Wide Joint Grout, a cement based grout, so I'm not sure which of the above would be best. Any suggestions?
Thanks again :|
Thanks again :|
NotSoHandyMan
grout on tiles
Hi Have been cleaning mine by scraping gently with a stanley blade in a scraper holder bought from B&Q and then cleaning with a soft scourer. This hasn't damaged the tiles and I am very pleased with the result although I have to say one wall tiled from floor to ceiling has taken nearly two days so not a nice job!!!
- plumbing and property
Re: Grout marks on tiles
I'm not surprised - Spirit of Salts is Hydrochloric Acid. Please anyone reading this and thinking of doing the same thing take extreme care.notsohandyman wrote:Just by way of an update, I thought I'd let you know how I've got on.
Thanks again :|
Treat everyone like they are a rich distant relative, in whose will you'd like to be remembered.
Yeah, it's pretty aggresive stuff, not a patch on the drain cleaner I once used, that attacked my polo shirt whilst I was working in an office block. I had to walk through the office with my top off.
Needless to say I got a few phone numbers from admiring female office workers.
Note: some parts of my post aren't true
Were you drinking a can of Coke too?bstyle wrote:Yeah, it's pretty aggresive stuff, not a patch on the drain cleaner I once used, that attacked my polo shirt whilst I was working in an office block. I had to walk through the office with my top off.
