Was scratching my noggin for cutting square holes in tiles until I found the UHM video on cutting holes. Wotrked a treat Looks neat around a socket / switch
Although I couldn't understand that if you mark the square on the tile and have it face down to the cutting wheel how can you line it up properly
I just drilled 4 pilot holes in each corner so at least I could see the blade spinning through the holes
Oh, are you suppose to use water when doing it. I was getting sprayed in the face constantly
Found the PMF 180e far too slow. Cermaic Jigsaw blade was ok but no as fast at the wheel cutter
Square hole
- Mr. Grumpy
- Has thanked: 25 times
- Been thanked: 109 times
- Mr. Grumpy
- Mr. Grumpy
