Wireless networking
scot-canuck
Has thanked: 247 times
Been thanked: 314 times
Wireless networking
Post by scot-canuck »
For any of you using wireless networking for business and able to switch from WPA to WPA2 encryption, then it might be a good time to do so.
Reason WPA is now attackable, however to do it you have to be relatively close to the access point so shouldnt be much risk in a home environment.
WPA2 is the successor to WPA and uses a different form of encryption which hasn't been cracked and currently isn't expected to be cracked.
Link : http://www.theregister.co.uk/2009/08/28/wpa_60sec/
Foggy
Post by Foggy »
rs232
Has thanked: 3 times
Post by rs232 »
I would advice everybody to enable mac filtering together with WPA encryption; still.
It's a pain in the neck to setup but once up and running it's rather secure.
If you want to give it a go, allow your your devices to connect. From your router administration page you should see the MAC address of the devices, if so copy+paste them into the mac filtering section of the router allowing only the specified one. if not run:
Code: Select all
ipconfig /all
on each pc/laptop connecting via wireless and get the mac address of the wireless NIC only.
my 2 cents
rs232
Return to “Computers”
