Cutting a Curve on a Kitchen Worktop
Kate Bygrave
Contact:
Post by Kate Bygrave »
big-all wrote:gotcha your rough cutting with a jigsaw
Well it wasn't my intention; in fact it is the reason I posted this thread.
I tried cutting the worktop with a jigsaw and it didn't work out. Now i believe I have a solution.
Has thanked: 736 times
Been thanked: 2341 times
i have been thinking about this a router cutter with a bearing cant do multiple passes on a surface as the cutter can only cut full length off the cutting edge so unless youve got a bearing cutter with a 6mm cutting edge and extra long shaft it wont work :cb :cb
Hitch
Has thanked: 77 times
Been thanked: 335 times
Post by Hitch »
Why not do a 20mm deep cut (in passes) with a 8mm diameter cutter, on the radius you want, using the trammel bar....
Then use the jigsaw to carefully cut on the waste side of the routed slot. The offcut will then be out of the way, and youd be left with a 20mm high, but only 5mm or so deep step...
Then use the bearing guided cutter from the opposite side, at maximum depth. Take it steady and dont push it in hard and it should be fine i'd think.
Kate Bygrave
Contact:
Hitch wrote:Why not do a 20mm deep cut (in passes) with a 8mm diameter cutter, on the radius you want, using the trammel bar....
Hi Mitch, :)
That's pretty much what I'm doing except I've already cut the radius with a jigsaw; so I'll do an initial pass with the router (20mm is a good width to remove) for a moderate say 3mm average depth.
Then turn I'll trim the excess with bearing guided cutter as you suggest.
I shall do some practice runs on offcuts as this is my first routing experience.
Hitch
Post by Hitch »
Dont forget to go in the right direction Kate.
The rotating cutter needs to be pushed into it, otherwise it will try and push itself away. It will become obvious when you are looking at it . :thumbright:
Kate Bygrave
Contact:
Hitch wrote:Dont forget to go in the right direction Kate.
Thanks Hitch,
That's something I had not realised. :)
python
General Builder
Been thanked: 7 times
Post by python »
gl kate
Kate Bygrave
Contact:
python wrote:gl kate
ty python.
It'll probably be a week or so yet, because I'm putting plumbing in for a new boiler!
Kate Bygrave
Contact:
I've done it; I've finally got round to doing it.
What I did was use the router with the bar and pin attachment on the underside of the worktop to scribe a radius with a straight router bit.
Then I used a straight bit with a bearing and cut it from the top side.
It looks perfect.
You have to make sure you measure everything very accurately though and make allowance to 'cut in' to allow the laminate edging to be stuck on.
I am very pleased; now a question...
Kate Bygrave
Contact:
Contact Adhesive
Now I need to stick on the laminate edging strip.
If you've done this before had success with it; could you recommend a type/brand as I don't know where to start and I'd like to get this right.
you normaly get a stip with the worktop in the packaging
it may be quite tricky to get unless its a plain colour without pattern
where did the worktop come from!!!
Has thanked: 1415 times
Been thanked: 4024 times
big-all wrote:you normaly get a stip with the worktop in the packaging
big all I think the question was "What brand of contact adhesive.."
evo stick as good as any.
yep i think you are right in both respects :thumbright: :thumbright:
evostic :thumbright: :thumbright:
Kate Bygrave
Contact:
Yes, sorry I should clarify; it's the adhesive I was referring to.
Thank you Wine~O
wonky windows
Post by wonky windows »
i was fitting a kitchen last week and didn't have my curve jig with me. as it was the last job to do in the kitchen i wanted to get it finished so i improvised by clamping two pieces of the kids 'scalectrix' track and used it to guide my router. :thumbright:
Locked
Return to “Kitchen Fitting”
