My bad attempt and end feed soldering
Diy disaster stories in this forum please, Tradesmen disaster stories are also welcome in here!
Hinton Heating
Gas/Heating Expert
Been thanked: 9 times
Post by Hinton Heating »
i'd disagee, I dont trust them to seal, so would use extra solder! in which case, an normal end feed is just teh same, & cheaper!
Slugster
Post by Slugster »
Done the solder ring stuff, read what the guys here said and thought I'd give end feed a go.
To be honest I had about 6 practice goes and they were pretty good. It shows the difference between trying something on your workbench nicely held in a vice and doing it for real upside down with your head stuck under the floor...
I like a challenge. That's why I have a wife and a cat :lol:
Nothing you do is a waste of time - especially if it can be used as a bad example by others...
Site Admin
Has thanked: 1012 times
Been thanked: 918 times
I have only used end feed twice-
Once for the how to page on here- http://www.ultimatehandyman.co.uk/diy_p ... d_feed.htm
and once on a gas pipe (in my own home)
Hinton Heating
Gas/Heating Expert
urgghhhh... wire wool, i hate the stuff!
Good tip about not using ur fingers to apply flux, doesn't have hurt when it gets in the cuts caused by the wirewool!
A kitchen scouring pad is just as good, or easy clean strip (cant remember the trade name right now)
Only-Me
Been thanked: 3 times
Post by Only-Me »
Looks better than my last attempt :oops: :oops:
Locked
Return to “DIY Disasters”
