no more ply
jaxonian
Has thanked: 14 times
no more ply
Post by jaxonian »
Hi there,
has anyone ever used a product called "no more ply"? A friend advised I use it for my bathroom floor but it's not easy to find...also a bit expensive.
Jaxonian
Site Admin
Has thanked: 1012 times
Been thanked: 918 times
I have never heard of it to be honest :scratch:
But having just done a google search it appears to be similar to tilebacker board/hardibacker/aquapanel.
lamntile
Contact:
Post by lamntile »
Unless your creating a wet room plywood is the cheapest method of sorting an unstable floor for tilling
Paul
tictic
Has thanked: 5 times
Been thanked: 23 times
Post by tictic »
cement based backer boards are the same price or there abouts as wbp ply...wbp is imo going out the tiling market shortly to c/b/b/b.. imo more realibile i have had a good few jobs fail because of the wbp being contamimated with oils..an the sticky stuff they put on the ply to stop it sticking together when on top of each other... :cb
jaxonian
Post by jaxonian »
the existing floor is some kind of fibre board. tried to attach a pic but couldn't get it to work. can i tile strait on top of this?
dave.m
Deceased 07-06-2012 R.I.P
Has thanked: 13 times
Been thanked: 318 times
Post by dave.m »
jaxonian wrote:tried to attach a pic but couldn't get it to work.
This should help with posting pictures:
how-to-post-pictures-t254.html
dave
But you cannot tell him much.
jaxonian
floor
Post by jaxonian »
can i tile directly onto this floor?
jaxonian
floor
Post by jaxonian »
here's \a second pic. I have flexible adhesive and grout and it's 60 sq/ft.
Site Admin
Looks like chipboard.
What type of tiles are you fitting ie-
marble, porcelain
jaxonian
Post by jaxonian »
they're porcelain and they're 10mm thick and 60cmx30cm, I bought flexible adhesive and grout also. I screwed down the only creak i found. will it need more screwing down do you think? I'd rather not have to put a backer board down but also i'd also i don't want it to crack up either! :scratch:
tictic
Post by tictic »
screw the exsisting boards to joists "looks like nails" in ur pics....
then u will HAVE to overboard with 18mm wbp ply,no more ply,..or 6mm backerboards..imo 6mm backerboards mate..
prime floor with bal sbr
thinset addy on floor lay 6mm b/boards screw them down leave gap between boards
then tile away
best of :thumbright:
tictic
Post by tictic »
make sure ur addy is suitable for porcelain tiles mate
tictic
Post by tictic »
u could look into ditra matting to mate..
jaxonian
Post by jaxonian »
Thanks for all your advice. I now have a lovely bathroom floor! Anyone want to see a pic?
