I'm fitting a breakfast bar/worktop ( 1000mmx600mm) To a solid wall, I have legs for the free end is there any specific way to mount it to the wall, I have some brackets to screw into the work top and wall should this be enough or will I need something more substantial, is there any specific mounting screws that I should use, any advice apreciated.
Neil
Fitting a breakfast bar
- Has thanked: 736 times
- Been thanked: 2341 times
a bit late now but if you are tiling afterwards or are happy with a 3mm bead between wall and top
use the "L" shaped brackets that come in the worktop packs
mark the wall where you want the underside off the worktop to sit
draw a line 2mm below the marks
secure the brackets to the wall above the line with the base between the lines
now slide the worktop onto the brackets covering the screws and bracket attached to the wall
go for a bracket at 950 630 and 310[assuming 1m long and support at zero]
you will have to slightly chamfer where the brackets are
