can I use Aquapanel cement board on the floor?
gez
Post by gez »
Hi, I am tiling a utility roomwith that has a P5 chipboard floor on top of old ceramic tiles, so its flat and non-flexing. I need to raise the floor by approx another 15mm + tile thickness to be level with the kitchen.
I plan to use Aquapanel cement board laid directly on top of the chipboard and then use a flexible tile adhesive, however I've just laid a board down (without screws) and walked on it and it made noises like it was cracking inside.
Have I bought the wrong product, or will it be ok when screwed down? Should I lay a thin layer of flex adhesive onto the chipboard before I bed the cement board down?
Advice welcomed.
tictic
Has thanked: 5 times
Been thanked: 23 times
Post by tictic »
is it aquapanel THERMAL these are the ones for floor u will put a thinset flexy addy down first 5/6mm trowel then screw leave a 2/3mm gap between boards then use the tape provided with them to taper over.
check their webpage for fixing instructions mate
best of.
