cutting cracked glaze tile
gbc
Post by gbc »
I've just finished putting in a new kitchen for my mother-in-law and I'm now at the tiling stage. The tiles she chose have a cracked glaze finish, and whichever way I try and cut them, I end up with chips out of the glaze where I've made the cut, at least one of which is too big to be disguised with grout.
I've tried everything up to an electric bench saw with diamond blade.
Is there a knack to cutting these tiles, or, considering the amount of cutting around sockets etc. involved, was it just a poor choice of tile.
My credibility is at stake here, so any help would be appreciated.
Beachcomber
Has thanked: 28 times
Been thanked: 71 times
Post by Beachcomber »
You'll need a wet cutter - diamond blade without water will overheat and damage the tile when you cut.
You can get a decent cheap one at Wickes:
http://www.wickes.co.uk/450W-Tile-Cutti ... nvt/186878
tictic
Has thanked: 5 times
Been thanked: 23 times
Post by tictic »
try a diamond resin blade, also as above wet saw cut nice an slow wear goggles.
gbc
Post by gbc »
thanks for that, but it is a water cooled saw.
Has thanked: 1414 times
Been thanked: 4019 times
have you tried cutting with the glazed side down?
gbc
Post by gbc »
Yes, tried that as well....it's actually worse as the problem, to my mind, is that the glaze isn't as well bonded to the tile as it should be. Fixing masking tape to the tile, something else I've tried, doesn't have any advantage either.
Thanks anyway.
mmm.........can only suggest cutting slightly larger than you need to, then carefully filing back to size, sounds a PITA of a job :roll:
gbc
Post by gbc »
Thanks, best suggestion yet.............. however, given the amount of cutting involved, 6 sockets and a light switch, I think I'll go to plan F... and take them back to Cosmo and exchange for something more practical.
Cheers.
thescruff
Has thanked: 360 times
Been thanked: 3735 times
Post by thescruff »
It would be interesting to see what the manufacturer recommends.
Are you cutting them face up or down.
