Scaffold tower
Hitch
Has thanked: 77 times
Been thanked: 335 times
Scaffold tower
Post by Hitch »
Fitting some doors, customer to supply a tower for us to get to the top hinges....
This is what they set up for us :lol: :lol: :shock:
Boards are at 4metres
Mooncat
Has thanked: 81 times
Been thanked: 72 times
Post by Mooncat »
I also like the lack of toe-boards and handrails, together with the springiness of the planking! :sad:
thescruff
Has thanked: 360 times
Been thanked: 3735 times
Post by thescruff »
Ladders tied in with the new invisible string I notice.
Did you actually go up there :roll:
handyman
Has thanked: 6 times
Been thanked: 11 times
Post by handyman »
big puff..........just get on with it :lol:
Hitch
Post by Hitch »
I told them it was crap, needs a handrail at the very least.
Planking was okay, theyre not normal scaff boards, theya re about 3" thick.
Heres the rail they fitted :lol: :lol: May aswell not bothered :?
Its about 700mm from the planks, just right to trip on ;)
Site Admin
Has thanked: 1012 times
Been thanked: 918 times
Hope you had an hard hat on :wink:
17edSparkyJoe
Been thanked: 7 times
Post by 17edSparkyJoe »
Reminds me of a site I worked on a couple of years back, customer employed some polish to paint the outside of a 3 story house. They decided it was easiest rather than to get a proper scaffold put up that they would just stack 3 towers ontop of each other, held to the house only by a bit of bailer twine wrapped around the soil pipe. Nice.
Painter-aberdeen
Post by Painter-aberdeen »
I've had my scaffold moments lol worked on a series of pre fab units about 10 stories high 6 feet apart.Yep one 12 ft scaffold plank on the roofs was your "staircase" nothing but a plank and a 100ft drop.
The gaffer walked right across,I though FM,I just did the same and when you got to the middle it dropped 3-4 inches,that was a good feeling..NOT!
You got used to it,this was years ago nowadays you'd probably get locked up for it.
Simon Site Manager
Has thanked: 48 times
Been thanked: 202 times
Re: Scaffold tower
Post by Simon Site Manager »
You wouldn't get me up on that Hitch!
S
Measure twice, cut once!
speed
Has thanked: 35 times
Been thanked: 257 times
Re: Scaffold tower
Post by speed »
ive been on worse...
kellys_eye
Has thanked: 357 times
Been thanked: 1790 times
Re: Scaffold tower
Post by kellys_eye »
speed wrote:ive been on worse...
and I used to have to balance on t' shoe box int' middle o' the road..... :lol:
yourweb
Re: Scaffold tower
Post by yourweb »
no cross support. Must be the very old kind that says work on it at your own risk. I can rent better scaffolding than this stuff. WWII made I would guess
Return to “Rogues Gallery”
