Well it wasn't my intention; in fact it is the reason I posted this thread.big-all wrote:gotcha your rough cutting with a jigsaw
I tried cutting the worktop with a jigsaw and it didn't work out. Now i believe I have a solution.
A-Z CONTENTS | DISCLAIMER | DIY VIDEO | HOME | SAFETY FIRST | FORUM RULES
Hi Mitch, :)Hitch wrote:Why not do a 20mm deep cut (in passes) with a 8mm diameter cutter, on the radius you want, using the trammel bar....
Then use the jigsaw to carefully cut on the waste side of the routed slot. The offcut will then be out of the way, and youd be left with a 20mm high, but only 5mm or so deep step...
Then use the bearing guided cutter from the opposite side, at maximum depth. Take it steady and dont push it in hard and it should be fine i'd think.
big all I think the question was "What brand of contact adhesive.."big-all wrote:you normaly get a stip with the worktop in the packaging
it may be quite tricky to get unless its a plain colour without pattern
where did the worktop come from!!!
yep i think you are right in both respectswine~o wrote:big all I think the question was "What brand of contact adhesive.."big-all wrote:you normaly get a stip with the worktop in the packaging
evo stick as good as any.
Yes, sorry I should clarify; it's the adhesive I was referring to.wine~o wrote:big all I think the question was "What brand of contact adhesive.."big-all wrote:you normaly get a stip with the worktop in the packaging
