Citroen ZX injection pump leak
Russellf97
Post by Russellf97 »
I have the same problem as 'village idiot' posted on 06/04/2008; fuel weeping from the throttle spindle on a Lucas/CAV injection pump.
On 07/04/2008 'village idiot' posted;
"it's the lucas, have taken top cover off & removed the 2 "O" rings off shaft
will get a couple of new ones tomorrow & hopefully job's a goodun"
If he reads this, where did you source the o-rings: Were they from Citroen, or a diesel workshop, or where..., and was it a straightforward job - and more importantly, did it cure the leak?
I'm in the process of matriculating the car in France and have the French CT (MOT) tomorrow; hopefully it won't be a fail point. :help:
Hitch
Has thanked: 77 times
Been thanked: 335 times
Post by Hitch »
Unless its a very serious leak, i doubt it would be an issue, not for an MOT here anyway.
village idiot
diesel demon
Has thanked: 104 times
Been thanked: 104 times
Post by village idiot »
just used standard o rings, we have the usual selection boxes at work so found a couple that fitted & used them
i love being married
it's great to find that one special person that you want to annoy for the rest of your life
I have a soft spot for the wife, it's a peat bog just outside Ardross
Still Yes Highland
Russellf97
Ah, righto; thanks for that. I'll give it a whirl.
village idiot
diesel demon
it was an easy enough job though fiddly, just had to make sure nothing fell into the pump
Still Yes Highland
Russellf97
Yep, job done. Many thanks for your help :thumbright:
A pack of variously-sized o rings was 3.27euros from my local BricoMarche - and I'm sure I can find a use for all the others...
And yes, a fuel leak is a reason they will fail a car over here - guess how I know... :cb
