Stuart turner shower pump
Hinton Heating
Gas/Heating Expert
Been thanked: 9 times
Post by Hinton Heating »
I removed a showermate pump this week... anyone what it? Postage may be a bit steep, as a heavy lump of pump!
jason123
Post by jason123 »
Single or double impeller???
Stella Stella Stella oy oy oy
Hinton Heating
Gas/Heating Expert
it pumps both hot & cold, connections are all at one end.
Hinton Heating
Gas/Heating Expert
RichieP
UHM Super Moderator
Has thanked: 4 times
Been thanked: 12 times
Post by RichieP »
Really, really stupid question, but will that draw up water from the tank, then down and across to the shower?
Dirk Diggler
BANNED
Post by Dirk Diggler »
RichieP wrote:Really, really stupid question, but will that draw up water from the tank, then down and across to the shower?
generally thats what pumps do, though the wording of your question could be somewhat ambiguous. when you say draw UP from the tank what exactly do you mean, its generally better to have the pump located below the tank in the instances ive found.
if there is insufficient head to feed the shower then a negative head kit can be fitted
[url=http://www.ultimatehandyman.co.uk/diy/decking/index.htm]Decking[/url] | [url=http://www.directory.ultimatehandyman.co.uk/plumbers/]Plumbers[/url]
bathstyle
BANNED
Post by bathstyle »
Let us know if you take any Monsoons out Spike :thumbright:
Hinton Heating
Gas/Heating Expert
I took one out last month, but it was faulty, so it got scrapped
RichieP
UHM Super Moderator
Post by RichieP »
That's why I used the word up.
The tank's in the airing cupboard, the pump is in the loft.
Dirk Diggler
BANNED
RichieP wrote:That's why I used the word up.
bad design
RichieP
UHM Super Moderator
Post by RichieP »
Probably is. But seeing as that's how it was when I moved into the house I'm not going to spend unnecessary money changing it.
Have you actually got anything constructive to add to this thread?
Jaeger_S2k
Pro Handyman
Has thanked: 20 times
Been thanked: 27 times
Post by Jaeger_S2k »
Jaeger.
Hinton Heating
Gas/Heating Expert
providing the pump & oulets ar below the level of water in the cold tank, then youonly need a normal pump, like the one I want to give away.
If the outlets above the water tank, then you need a negitive head version.
Jaeger_S2k
Pro Handyman
Richie,
Quick question, do you have a shower at the moment and just want better pressure?
Jaeger.
Dirk Diggler
BANNED
RichieP wrote:Probably is. But seeing as that's how it was when I moved into the house I'm not going to spend unnecessary money changing it.
:shock: your a shirty boy arent you, we are not at home to mr rude.
i have added constructive information richie(see above), now stop acting like your avatar :thumbright:
Return to “General DIY forum”
